RexCore Plus for UniPi Neuron/Axon/Patron
Frequently asked questions
The licence allows you to run your algorithms on a single UniPi Neuron/Axon/Patron device. As soon as the licence is bound to your controller, it cannot be used for another device. The development tools are free to use on any computer.
How is the licence delivered?
The licence is delivered via e-mail as an electronic token, which you combine with the identifiers of your UniPi Neuron/Axon/Patron device to form a valid licence key. The procedure is described in detail in the Getting started guide.
Absolutely! You can buy the optional communication drivers whenever you need them. If you wish to upgrade your RexCore Plus to Professional version, just contact us.
What if my UniPi Neuron/Axon/Patron is broken?
In 99% of the cases, problems are solved by reflashing the operating system and/or replacing the faulty I/O modules. In such a case, your licence is still valid. In other cases you contact us and we'll do our best to find a win-win resolution.
Modbus communication driver
Connect your controller to energy meters, frequency inverters, remote I/O units, other PLCs or SCADA systems using the Modbus protocol. Your device can act as Modbus master or Modbus slave. Both TCP and RTU (serial communication) variants are supported.
Driver for database access
Connect your device to database systems (e.g. MySQL, PostgreSQL, Microsoft SQL). You can archive measured data, read user-defined parameters, read predefined sequences or recipes for individual machines, store data for reports in ERP and BMS systems, etc.
If you ever struggled with PI or PID controller settings, you probably understand the benefits of automatic tuning of controller parameters.
