can I ask for the way, how to include in RexLang srcfile.c next file with some functions, if it is possible?
I try the same as in C-programs:
srcfile.c
#define VAL1 10
#include "secti.h"
double output(0) firstoutput;
double output(1) secondoutput;
int count = 0;
long init(void)
return 0;
long main(void)
firstoutput = soucet(count, VAL1);
secondoutput = VAL1;
return 0;
long exit(void)
return 0;
}secti.h
#ifndef SECTI_H_
#define SECTI_H_
int soucet(int a, int b);
#endif /* SECTI_H_ */secti.c
#include "secti.h"
int soucet(int a, int b){
return (a + b);
}But the compilation ends with this messahe:
Error compiling file 'secti.h' (line 4): syntax error
srcfile.c [3] warning: comment or #ifdef not end in current file
[0] warning: comment or #ifdef not end in current file
Error 125: The configuration validation error occured in:
Error 126: Validation error -220 (REXLANG compilation error) in the pin 'rex3_proces.REXLANG:srcname'
Thanks for help.
Hi bodie,
thank you for your question. In general, it is possible to include other C files in Rexlang.
However, including header files (".h") is not supported. It means that you have to include only source files (".c") with declaration inside.
Hope it helps. If you require any further information, let me know.
thanks for your advice, I will try it.
