#1 2016-12-04 22:33:11
New TRND not showing up in Archive
What can be the reason why a newly created TRND is not showing up in the assigned archive?
The archive was already used for other TRND function blocks but they all have a unique ID's.
#2 2016-12-05 08:13:22
Re: New TRND not showing up in Archive
Solved.....as my archive already contained a few days of data it takes a while before the new ID's show up in the list in REXview's ARC graph window. The loading of the graph takes also a lot of time once you have a lot of data.....
It seems that every single data point is loaded to build the graph....(as I only have a limited amount of pixels on my monitor to visualize all the data it would make sense to load only the data which is needed to draw the graph.....I guess.....)
#3 2016-12-05 10:54:02
Hi scoobsalamander,
thank you for your comments - we are aware that archives in the current version are not fully optimised. We will improve it in future versions.
