Getting started with REXYGEN on Monarco HAT
1.4.5 REXYGEN Diagnostics
2.1 Windows 7/8/10
3 Installing the runtime modules of the REXYGEN system on Monarco HAT
3.1 Install using operating system image with REXYGEN
3.2 Installation with a script
3.3 Manual installation on running Raspberry Pi
3.4 Starting the runtime
3.5 Installed files and folders
4 Licensing REXYGEN using REXYGEN DWM on Monarco HAT
4.1 Obtaining a DEMO licence
4.2 Obtaining a permanent licence
4.2.1 Activation of the permanent licence
5 Default REXYGEN project on Monarco HAT
5.1 Control Monarco HAT from HMI
5.2 Control Monarco HAT through OPC UA
5.3 Loading project from Monarco HAT to REXYGEN Studio
6 Configuration, compilation and execution
6.1 Creating a new project
6.2 Compiling and running a project
6.3 Adding a user interface (HMI)
6.4 Ready for interaction with the outer world
7 I/O configuration for the Monarco HAT
7.1 Physical connections
7.2 Adding inputs and outputs to the project
7.3 Working with I/O signals
7.3.1 Modifications in the project main file
7.3.2 Modifications in the task
7.4 Updating the HMI
7.5 Additional information
7.5.1 Detailed description of the driver
7.5.2 Examples
8 Summary
B Raspberry Pi OS image with REXYGEN
B.1 Commissioning the image
B.2 Changes
C Licensing of the REXYGEN system
C.1 Obtaining a DEMO licence
C.2 Obtaining a permanent licence
C.2.1 Activation of the permanent licence
The runtime core of the REXYGEN system turns your Raspberry Pi into a programmable device which will run your algorithms.
- Wide family of supported devices and input-output units (including Monarco HAT)
REXYGEN Studio is a developer’s tool which runs on a standard PC with Windows. You create the algorithms using the function block library (The IEC 61131-3 standard defines Function Block Diagram (FBD) as one of the PLC programming techniques.) of the REXYGEN system [1]. The library contains simple comparators and timers as well as advanced blocks for signal processing and feedback control (PID controllers etc.). You compile your project on your PC and run it on your Raspberry Pi.
The REXYGEN HMI Designer is another developer’s tool intended for designing graphical user interface (or HMI, Human Machine Interface, if you prefer) for your algorithms. The user interface is included in the project and it is copied to your Raspberry Pi along with the algorithm.
The RexCore (REXYGEN runtime core) service runs on the target device (Raspberry Pi). Once installed, it runs in the background and therefore it is almost invisible for the user. It handles timing and execution of your algorithms and provides various services. The individual tasks are prioritized and executed using preemptive multitasking. The RexCore service is automatically started at system startup.
RexCore further contains an integrated webserver providing user interface (HMI) and REST API. Chapter 3 deals with installing all the necessary modules on Raspberry Pi.
With REXYGEN Diagnostics you can diagnose the runtime core and execution of your algorithm. It is an alternative standalone tool for commissioning and diagnostics of control algorithms. All the diagnostic functions are included in REXYGEN Studio, therefore REXYGEN Diagnostics can be considered obsolete. You can connect via local network or over the Internet.
This chapter describes the steps to install and uninstall the development tools of the REXYGEN system on Windows 7/8/10 operating systems. The tools also run on various GNU/Linux distributions using Wine (http://www.winehq.org).
2.1 Windows 7/8/10
The installation package of REXYGEN development tools contains the REXYGEN Studio and REXYGEN HMI Designer development environments, the REXYGEN Compiler compiler and the REXYGEN Diagnostics tool. It also includes the RexCore (REXYGEN runtime core) module for developing and testing purposes.
Follow the instructions for installation under Windows 7/8/10 given in section 2.1. The installation is started with wine REXYGEN-X.XX.XX.XXXX-PPP.exe command entered at the console prompt. Some distributions (e.g. Ubuntu) allow running the installator by clicking the REXYGEN-X.XX.XX.XXXX-PPP.exe file.
HAT
IMPORTANT: This procedure will delete all old data and settings. Make sure you have all the necessary files stored elsewhere!
- It is highly recommended to use the latest version of official Monarco HAT OS
image with REXYGEN which you can download from
http://download.rexcontrols.com/images/. - After you download the file, write it to a SD card with a capacity of 4 GB or more.
You can use a Win32 Disk Imager for example:
https://sourceforge.net/projects/win32diskimager/. - Put the SD card in and power up your Monarco HAT.
- After operating system expansion (which is done automatically with the first boot), you can log in via SSH with name pi and password monarco.io. Please change the password using raspi-config or passwd as soon as possible.
For more information about preinstalled image see the Appendix B.
REXYGEN runtime may be also installed with a script that automates all the installation
tasks. Currently, following platforms are supported for full automatic installation: plain
Raspberry Pi, Monarco HAT, UniPi 1.1, PiFace Digital.
It is necessary to have a correctly configured Internet connection on your Raspberry Pi and running the so-called Raspberry OS distribution of GNU/Linux (RexCore should also work on any other distribution based on Debian (e.g. Ubuntu).) prior to using this guide. Visit http://www.raspberrypi.org for more information.
For plain Raspberry Pi, run the following commands:
chmod +x rex-install-rpi.sh
sudo ./rex-install-rpi.sh
For Monarco HAT, run the following commands:
chmod +x rex-install-monarcohat.sh
sudo ./rex-install-monarcohat.sh
For UniPi version 1.1, run the following commands:
chmod +x rex-install-unipi1_1.sh
sudo ./rex-install-unipi1_1.sh
For PiFace Digital extension board, run the following commands:
chmod +x rex-install-pifacedigital.sh
sudo ./rex-install-pifacedigital.sh
These scripts always install the stable branch of REXYGEN. The scripts also provide --testing and --next parameters (e.g. sudo ./rex-install-rpi.sh --testing) to install development branches. The "testing" branch contains a REXYGEN version that is to be released soon, but still under testing. The "next" branch contains the current state of a next REXYGEN version under development. Use these options carefully.
It is also possible to install the RexCore (REXYGEN runtime core) on running Raspberry Pi manually. Following instructions guide you through installation of REXYGEN runtime on plain Raspberry Pi OpenSource OS. See documentation for other platforms for specific installation steps.
- Install some necessary packages:
sudo apt install wget gnupg2 - Add REXYGEN public key:
wget -nc https://download.rexcontrols.com/files/key/rex-debian-key.pub
sudo apt-key add rex-debian-key.pub - Add the repository to /etc/apt/sources.list or create a new *.list under
/etc/apt/sources.list.d/ with the following content:
deb http://download.rexcontrols.com/repositories/debian-rex-2.50/ bullseye non-free
deb http://download.rexcontrols.com/repositories/rex-dwm/debian bullseye non-freeReplace bullseye with buster or stretch if you are still running the older Debian distribution. Replace debian-rex-2.50 with debian-rex-2.50-testing or debian-rex-2.50-next to install development branches. The "testing" branch contains a REXYGEN version that is to be released soon, but still under testing. The "next" branch contains the current state of a next REXYGEN version under development. Use these options carefully.
sudo apt install rex-dwm - Perform specific installation steps for your platform (Monarco HAT, UniPi 1.1, PiFace Digital etc.).
Right after the installation, the RexCore runtime module is started automatically in the background as a daemon and it is possible to establish connection between the host PC and the Monarco HAT using the REXYGEN Studio program. RexCore also automatically runs upon system (re)start.
The first thing you will need is to get the license. The fastest way is to use the REXYGEN DWM tool. Open your web-browser and input IP address of Monarco HAT. You should see the Device is not licensed! message on the bottom of the screen. Please, click on the Licensing.
- The RexCore runtime module always needs a licence to run on your Monarco HAT. There are DEMO licences available at no cost and there are permanent licences which you can purchase. Each Monarco HAT needs an individual licence.
Click on Get demo licence and you will be redirected to the registration form. Identify yourself and you’ll receive a DEMO licence key via e-mail. The licence key is called a SiteKey.
Once you have your DEMO licence key (SiteKey), apply it in REXYGEN DWMby selecting Apply Licence Keys and clicking on Apply keys.
Evaluation version of RexCore (REXYGEN runtime core) is functional for 2 hours. It is possible to run your algorithm on the Monarco HAT but you cannot store it permanently. The algorithm resides only in the RAM memory therefore it will not run after a restart or power-up. You can use almost all function blocks, see [1]. The RexCore runtime core on the target device is terminated after 2 hours of operation in demo mode without any warning. After a restart, you have another 2 hours for your experiments.
Each device running the RexCore runtime module is identified by the so-called SiteID tag. The purchased licence is associated with the hardware device, i.e. with the SiteID tag.
- Open your favorite web-browser on the desktop PC and fill in the IP address of
Monarco HAT. Once the DWM appears, select Licensing
Apply Voucher and enter your licence voucher code.
- If other licenses are already present, a new window will appear where you can
specify what should happen to the old licenses. Use the Overwrite option if the
Monarco HAT is running in DEMO mode. This is the last and irreversible
in your device, which is shown in the Active License panel. The licence key allows
permanent operation of the runtime core. It is highly recommended to check the licence
again after a reboot of the device.
In order to help you speed up a start with REXYGEN and Monarco HAT we have create an example project for Monarco HAT which is already preinstalled on the image with REXYGEN (installation is described in Section 3.1). The project serves as a basic validation of the installation process and as a starting point for more complex applications. One can control digital output(s) DO, analog output(s) AO, observe the state of digital inputs(s) DI and analog input(s) AI. These general inputs and outputs are present on all Monarco HAT models. The steps to create and develop a new project from scratch is described in Chapter 6 in detail.
IMPORTANT: If you have valid permanent licence stored on your Monarco HAT, this
project will start automatically once RexCore (REXYGEN runtime core) starts. Otherwise, if
you have only a Demo license, you must compile and download the project from
the REXYGEN Studio on the Monarco HAT first. The project can be opened in the
REXYGEN Studio using either the procedure described in Section 5.3, or the project can
also be found in the Examples library as 0121-09_Monarco_HAT_Demo_Example (All
examples which are part of the installation are marked by an ExampleID. The most
up-to-date examples are available with the latest installation of development tools or at
https://www.rexygen.com/example-projects/ ).
The process of compiling and running the project is described in Section 6.2.
The project contains graphical user interface (so-called Human-Machine-Interface) for easy control and observing of general outputs and inputs. The HMI can be found at URL address http://192.168.1.100:8008/hmi/index.html (replace 192.168.1.100 with the IP address of your Monarco HAT).
You can use the OPC UA interface to control your Monarco HAT too. Install any OPC UA
Client and connect to the OPC UA Server, which is running right now on your Monarco HAT.
There is the UAExport software used in this tutorial:
https://www.unified-automation.com/downloads/opc-ua-clients.html.
Click on Server in the Menu
Add
Advanced mode and fill the Configuration Name and the Endpoint URL (replace 192.168.1.100
After confirmation (OK), right-click on the new server name in the Project panel and choose Connect.
Congratulations, you are now connected to your Monarco HAT! You can now set the DO1 to value true for example. Navigate to Address Space panel and select DO1. In Attributes panel search Value Value, double-click on it, check the radio box and hit Enter. The first Digital outputs LED diod on Monarco HAT should glow. Detailed tutorial on using OPC UA with REXYGEN is there [3].
After installation of REXYGEN development tools (described in Chapter 2), you can open the REXYGEN Studio on your PC and download algorithm of this default project from your Monarco HAT.
Select Load Project from Target Device from starting dialog or from File Open Project from Target Device and connect to your Monarco HAT (replace 192.168.1.100 with the IP address of your Monarco HAT).
Choose the directory where will be the project stored on your PC and hit OK.
If everything went well, the project algorithm will appear.
The process of creating a control algorithm will be demonstrated on a very simple example with four Boolean variables representing manual switches. In Chapter 7, two of them will be replaced by physical inputs of the Monarco HAT. A software timer will be used for measuring the time when the variables are true (i.e. the switches are in the ON position). A Boolean signal will indicate that the interval of predefined length has elapsed.
Enter the IP address of your Raspberry Pi in the Target field.
If there is no licence on your Raspberry Pi, you need to get one first. You can get a DEMO licence for free. See Appendix C for details and come back afterwards.
Note: There is also a standalone diagnostics program called REXYGEN Diagnostics. Click the REXYGEN Diagnostics
and confirm the IP address of the target platform.
All changes made while in the Watch mode are not permanently stored in the target device (unless you decide so, see [4]). Upon restarting the RexCore runtime module the algorithm will start with the parameters defined in the project source files, which were valid when compiling and downloading the algorithm to the target device. To apply the changes permanently, you have to transfer the changes to the source files and Compile and download the project one more time which defines new startup values.
moment. See [5] for details, it is a very interesting tool for developers and
- See [5] for detailed information about WebBuDi elements and possible customization (colors, backgrounds etc.).
- The default URL address is http://192.168.1.100:8008/hmi/index.html (replace 192.168.1.100 with the IP address of your Monarco HAT).
We will use the input and output signals of the Monarco HAT for interaction with the real world.
As mentioned in Chapter 6, two physical switches will be connected as inputs and a software timer will control one output signal. In other words, this chapter is devoted to advancing from the generic example 0101-01 to example 0121-01 for the Monarco HAT.
Connect the switches as shown below. The motor is optional, the onboard LED will indicate the status of the output.
Now we tell the compiler to use the Monarco HAT I/O driver. To do this, edit the IODRV block parameters. Link the IODRV block with the MonarcoDrv module by setting
- – CASE SENSITIVE!
Continue editing the IODRV block parameters. For Monarco HAT set the following:
- – CASE SENSITIVE!
Remember to click the Configure button. This will create a default I/O driver configuration file (.rio). Keep the default values and close the dialog.
As the final step, rename the IODRV block to MNR, which will serve as a prefix for all I/O signals of this driver.
In the task double-click the input flag and set .Note the MNR prefix and two underscore characters. The first physical switch will be connected to DI1.
The second physical switch will be connected to DI2 (MNR__DI2).
The timer output will be routed to DO1 which will serve as the output signal (MNR__DO1).
Similarly for other inputs and outputs we could use the following flags:
- Goto, MNR__DO4 – digital output 4
- From, MNR__DI3 – digital input 3
- From, MNR__AI1 – analog input 1
A detailed description of the I/O driver for Monarco HAT is available in a separate manual [6].
The pinout of the Monarco HAT is shown in the following picture:
After compiling the project and downloading it to the Raspberry Pi the control algorithm interacts with the physical world. Again it is possible to switch to Watch mode and observe the signals in real-time or analyze the trends of signals. Flip the physical switches and watch the signals.
A detailed description of the IO driver for Monarco HAT is available in a separate manual [6].
7.5.2 Examples
Start from an Example Project and select one of the Monarco HAT examples. As
Congratulations, you have created the example 0121-01 from scratch! You have learned how to develop, compile and run your algorithms on the Raspberry Pi. The interaction with sensors and actuators is provided via input-output driver of the REXYGEN system, which you have learned to configure and use.
Chapter 6 describes the creation of a simple WebBuDi user interface. The REXYGEN development tools also contain the REXYGEN HMI Designer program which is a tool for designing custom graphical visualizations from predefined components (Definition of custom components is also possible but it requires a bit of Javascript coding.). The REXYGEN HMI Designer is based on the well-known open-source vector editor InkscapeTM https://inkscape.org/en/.
You can find the description of each component and property in [5]. Leave the default values
The Browser requires a target device with running algorithm. Make sure the algorithm is running, see Section 6.2. Also the target URL must be set. Press Browse button. The login dialog will be opened. Change Target to 192.168.1.100:8008 (replace 192.168.1.100 with the IP address of your Monarco HAT). Unless you changed the login credentials, use the default username admin with an empty password. After a successful login the connection tab is expanded with a tree-view of the running algorithm (you have already seen this tree-view in algorithm diagnostics).
As mentioned earlier, the *.hmi.svg files in the hmisrc folder are automatically processed while the project is compiled in the REXYGEN Studio application. The project main file must contain the HMI block with GenerateRexHMI parameter enabled. This was already covered in Section 6.3 so you should have everything ready.
Once you compile the project again and download it to your Raspberry Pi, the HMI will be
accessible via a web browser. Navigate to
of your Monarco HAT). You will see your HMI with live data.
This tutorial covers only the very basic components. If you want to get more information about additional components, see [5].
For fast use of REXYGEN on the Monarco HAT platform, an image of the Raspberry Pi OS (Official supported operating system by raspberrypi.org, see https://www.raspberrypi.org/software/operating-systems/.) is automatically generated. This image is prepared using RPi-Distro/pi-gen (Tool used to create Raspberry Pi OS images (previously known as Raspbian), see https://github.com/RPi-Distro/pi-gen.) and should contain everything you need to use Monarco HAT immediately for your projects. The image can be used on your Monarco HAT in four easy steps (see Section B.1). List of all changes comparing to the original Raspberry Pi OS image is shown in Section B.2.
IMPORTANT: This procedure will delete all old data and settings from your SD card. Make sure you have all the necessary files stored elsewhere!
- It is highly recommended to use the latest version of the official Monarco HAT OS
On Windows PC you can use a Win32 Disk Imager tool or any other software
capable of writing images:
- After operating system expansion (which is done automatically with the first boot), you can log in via SSH with name pi and password monarco.io. Please, change the password using raspi-config or passwd as soon as possible.
B.2 Changes
Changes compared to the official version of the image are listed bellow:
- SSH access is enabled by default.
- Following 3-rd party packages are installed:
- mc
- hdparm
- iperf
- screen
- tcpdump
- owserver
- owshell
- i2c-tools
- Following REXYGEN packages are installed:
- RexCore – latest release
- REXYGEN DWM – Device Web Management
- RexArc – utility to export data from REXYGEN Archives
- rex-monarcodrvt – REXYGEN driver for Monarco HAT
- rex-owsdrvt – REXYGEN 1-Wire driver
- The systemd-networkd daemon is used to manage network configurations.
- The eth1 is configured with parameter DHCP=yes. See
sudo nano /etc/systemd/network/eth1.network
This can be used for an Ethernet to USB adapter.
- RexCore log messages are stored in /etc/log/syslog (duplicate logging to a file /etc/log/messages is disabled).
- The datetime format for RexCore logs has been modified. The /etc/rsyslog.d/time.conf
file has been created and the
dateext
command was added into the /etc/logrotate.d/rsyslog.
Appendix C
- The RexCore runtime module always needs a licence to run on your Raspberry Pi. There are DEMO licences available at no cost and there are permanent licences which you can purchase. Each Raspberry Pi needs an individual licence.
Once successfully applied, your algorithm will download to your Monarco HAT.
[3] REX Controls s.r.o.. OpcUaDrv driver of REXYGEN – user guide, 2020. .
[4] REX Controls s.r.o.. REXYGEN Studio – User manual, 2020. .
[5] REX Controls s.r.o.. REXYGEN HMI – User manual, 2020. .
[6] REX Controls s.r.o.. MonarcoDrv driver of REXYGEN – user guide, 2020. .
Documentation reference number: 13771
2022 © REX Controls s.r.o., www.rexygen.com
