#1 2016-07-04 20:09:47
martijnperdaan
problum whit the 8-Relay Addon EMO-R8
i connected 2 times a 8-Relay Addon EMO-R8 board to my unipi but i can't find/controll them when i use the comand (sudo i2cdetect -y 1)
i don't see them and the data led on de 8-Relay Addon EMO-R8 board is red can anyone help me ?
gr Martijn Perdaan
ps. Sorry for my bad English
#2 2016-07-05 01:43:55
Re: problum whit the 8-Relay Addon EMO-R8
Hi Martijn,
if you can't detect the board with i2cdetect, there is no way REX could control it.
Did you check this post at UniPi forum: http://unipi.technology/forum/viewtopic.php?f=9&t=246
How long is your cable between the UniPi and the EMO-R8 expansion board? Did you make the cable yourself or did you buy it? Double check the cable, make sure that pin1 of the RJ12 connector goes to pin1 on the other end. Some cables are wired so that pin1 goes to pin4 and these will not work with UniPi and its extension modules.
Hope this helps,
#3 2016-07-05 11:24:21
martijnperdaan
Hi Jaroslav
i purchased the EMO-R8 expansion board and there was a cable whit it, it is about 10 centimeter lang
Gr Martijn Perdaan
#4 2016-07-06 11:11:08
Hi Martijn,
in this case it's necessary to contact the UniPi guys, who are the developers of the hardware. I can see you already did that in the UniPi forum. I'll let them know that you are our customer.
