#1 2016-04-08 02:43:42
sudhir
Multiple MODBUS RTU Slave
We figured out how to add another slave but the read registers of that slave are not appearing in the dropdown for creating a new tag.
Is there a tutorial on how to add multiple MODBUS slaves? Thanks.
#2 2016-04-08 11:45:00
Re: Multiple MODBUS RTU Slave
Hey sudhir!
Thank you for your question. Another slave can be added by adding a new "Item" where you specify the "Slave address". Read registers won't appear in the dropdown menu until you add the items manually.
There isn't a way how to determine read/write registers of different Modbus devices automatically. You need to look for Register Table in documentation of each Modbus slave.
Hope it will help you find the right way.
#3 2016-04-08 22:09:17
sudhir
Thanks. We added in the "Special Edit"  dialog "Slave2 Slave addr 2 ReadReg 16 at address 0" to the items list. We want to associate that read reg to a from tag. We can't find a way to do that.
#4 2016-04-08 23:31:21
sudhir
It appears to be a bug in the UI. We may to edit the mdl by hand.
#5 2016-04-11 07:35:14
Hello sudhir,
the association of registers to a "From" tag isn't done automatically. You need to specify "GotoTag" parameter in "From" tag in order to link the register with the tag (e.g. MBM__temperature - for more details see documentation). It is also possible to use "INQUAD, INOCT, INHEXD" and change their name to link with the registers (e.g. MBM__localIPaddress).
Hope that this is now a bit more clearer.
#6 2016-04-12 00:35:58
sudhir
The issue is that the new items don't appear in the dropdown to make the connections. You have to edit it by hand.
#7 2016-04-12 11:14:04
Do you mean the dropdown menu of "From" tag?
For now, it is a feature not a bug.
We see your point and share your idea. Unfortunately, it can't be implemented automatically because of multi I/O flags I mentioned in previous post.
Hope that this is not a big issue for you.
Have a nice day,
Tomas
