I do not see the WAGO 750-647 IO module (DALI) in the supported I/O modules list in the WagoDrv user guide.
Is there a way to work with this module or do you have an alternative to work with DALI ?
Richard
Hi Richard,
you are right, this module has not been tested. As I have no experience with this module, I can only guess that you'll need to configure it using the WAGO DALI Configurator (see the Download section at the WAGO 753-647 product webpage).
After configuration, the module will handle some part of the process data image and from there, you should be able to work with the data in REXYGEN.
As I said, it's only a qualified guess, which still can be completely wrong. I'll be happy to learn from this conversation, please let me know more details about the intended application (e.g. the number and type of DALI devices you are planning to use). I believe I could source the 753-647 module locally for debugging/testing.
With kind regards,
Thanks Jaroslav,
I have a bid for a job to replace a lighting system and use a WAGO PLC instead, using the DALI modules.
There will be about 60 DALI devices and i will use multiple 753-647 modules.
If this is happening, i will let you know, but this will likely be at the end of next year, so no rush ![]()
Richard
