This means that opening a connection to RexCore on the target device failed. Double check your IP address setting. Try if you can ping the target device.
I suppose you are running the demo version so it might have timed-out (2-hour limit). Try restarting it and you should be fine.
I did restart application + checked IP address...still do not work
What application did you restart? You have to restart RexCore on your Raspberry Pi (simply reboot it).
Can you ping the Raspberry Pi from your PC? Can you login e.g. via PuTTy? What is your IP address and netmask? How do you know the IP address of the Raspberry Pi?
Did the connection ever work?
Please paste here the output of the following command on your Raspberry Pi:
ps axMonarco HAT for Raspberry Pi - Lightweight I/O for monitoring, archiving and control.
My Pi has a static ip address. Everything worked fine before; I was downloading a project/ task and received the error message. I rebooted the pi several times; I can also ping the pi and log in with putty.
2 ? S 0:00 [fsnotify_mark]
23 ? S< 0:00 [nfsiod]
29 ? S< 0:00 [kthrotld]
30 ? S< 0:00 [VCHIQ-0]
31 ? S< 0:00 [VCHIQr-0]
32 ? S< 0:00 [VCHIQs-0]
33 ? S< 0:00 [iscsi_eh]
34 ? S< 0:00 [dwc_otg]
35 ? S< 0:00 [DWC Notificatio]
36 ? S 0:08 [kworker/u2:1]
37 ? S 0:00 [VCHIQka-0]
38 ? S< 0:00 [SMIO]
39 ? S 0:01 [mmcqd/0]
40 ? S< 0:00 [deferwq]
41 ? S 0:09 [kworker/u2:2]
42 ? S 0:00 [kworker/0:2]
43 ? S 0:00 [jbd2/mmcblk0p2-]
44 ? S< 0:00 [ext4-rsv-conver]
159 ? Ss 0:00 udevd --daemon
256 ? S 0:00 [spi0]
285 ? S 0:00 udevd --daemon
293 ? S 0:00 udevd --daemon
326 ? S< 0:00 [cfg80211]
408 ? S< 0:00 [kworker/0:1H]
1721 ? S 0:00 /usr/sbin/ifplugd -i wlan0 -q -f -u0 -d10 -w -I
1727 ? S 0:01 /usr/sbin/ifplugd -i eth0 -q -f -u0 -d10 -w -I
1736 ? S 0:00 /usr/sbin/ifplugd -i lo -q -f -u0 -d10 -w -I
1791 ? Ss 0:00 /sbin/wpa_supplicant -s -B -P /var/run/wpa_supplicant
1923 ? Ss 0:00 /sbin/wpa_cli -B -P /var/run/wpa_action.wlan0.pid -i
1936 ? S 0:10 [kworker/u2:3]
2143 ? Sl 0:00 /usr/sbin/rsyslogd -c5
2155 ? Ss 0:00 /usr/sbin/thd --daemon --triggers /etc/triggerhappy/t
2209 ? Ss 0:00 /usr/sbin/cron
2218 ? Ss 0:00 /usr/bin/dbus-daemon --system
2266 ? S 0:00 avahi-daemon: running [raspberrypi.local]
2267 ? S 0:00 avahi-daemon: chroot helper
2308 ? Sl 0:00 /usr/sbin/lightdm
2332 tty7 Ss+ 0:04 /usr/bin/X :0 -auth /var/run/lightdm/root/:0 -noliste
2440 ? Sl 0:00 lightdm --session-child 11 14
2457 ? Ss 0:00 dhclient -v -pf /run/dhclient.wlan0.pid -lf /var/lib/
2462 ? S 0:00 /usr/sbin/lighttpd -f /etc/lighttpd/lighttpd.conf
2475 ? Sl 0:00 /usr/sbin/console-kit-daemon --no-daemon
2570 ? Sl 0:00 /usr/lib/policykit-1/polkitd --no-debug
2585 ? Ss 0:00 /usr/sbin/ntpd -p /var/run/ntpd.pid -g -u 104:107
2634 ? Ssl 0:00 /usr/bin/lxsession -s LXDE-pi -e LXDE
2652 ? Ss 0:00 /usr/bin/owserver -c /etc/owfs.conf --pid-file /var/r
2686 ? Ss 0:00 /usr/bin/ssh-agent /usr/bin/dbus-launch --exit-with-s
2692 ? S 0:00 /usr/bin/dbus-launch --exit-with-session x-session-ma
2699 ? Ss 0:00 /usr/bin/dbus-daemon --fork --print-pid 5 --print-add
2717 ? S 0:00 /usr/bin/RexWSTcp
2740 ? Ss 0:00 /usr/sbin/sshd
2770 ? S 0:04 Xtightvnc :1 -desktop X -auth /home/pi/.Xauthority -g
2777 ? S 0:00 openbox --config-file /home/pi/.config/openbox/lxde-p
2779 ? Sl 0:19 lxpanel --profile LXDE-pi
2786 ? Sl 0:00 /usr/lib/arm-linux-gnueabihf/lxpolkit
2790 ? S 0:00 /bin/sh /home/pi/.vnc/xstartup
2798 ? S 0:00 /usr/bin/ck-launch-session /usr/bin/dbus-launch --exi
2843 tty1 Ss+ 0:00 /sbin/getty --noclear 38400 tty1
2844 tty2 Ss+ 0:00 /sbin/getty 38400 tty2
2845 tty3 Ss+ 0:00 /sbin/getty 38400 tty3
2846 tty4 Ss+ 0:00 /sbin/getty 38400 tty4
2847 tty5 Ss+ 0:00 /sbin/getty 38400 tty5
2848 tty6 Ss+ 0:00 /sbin/getty 38400 tty6
2849 ? Ss+ 0:00 /sbin/getty -L ttyAMA0 115200 vt100
2853 ? Ss 0:00 /usr/bin/ssh-agent /usr/bin/ck-launch-session /usr/bi
2859 ? Sl 0:00 /usr/bin/lxsession -s LXDE-pi -e LXDE
2862 ? S 0:00 /usr/bin/dbus-launch --exit-with-session x-session-ma
2863 ? Ss 0:00 /usr/bin/dbus-daemon --fork --print-pid 5 --print-add
2867 ? S 0:00 /usr/lib/gvfs/gvfsd
2874 ? Sl 0:00 /usr/lib/gvfs/gvfs-gdu-volume-monitor
2877 ? Sl 0:00 /usr/lib/udisks/udisks-daemon
2878 ? S 0:00 udisks-daemon: not polling any devices
2886 ? S 0:00 openbox --config-file /home/pi/.config/openbox/lxde-p
2888 ? Sl 0:20 lxpanel --profile LXDE-pi
2895 ? Sl 0:00 /usr/lib/arm-linux-gnueabihf/lxpolkit
2897 ? S 0:00 /usr/lib/gvfs/gvfs-gphoto2-volume-monitor
2899 ? Sl 0:00 /usr/lib/gvfs/gvfs-afc-volume-monitor
2904 ? S 0:00 /usr/lib/gvfs/gvfsd
2911 ? Sl 0:00 /usr/lib/gvfs/gvfs-gdu-volume-monitor
2914 ? Sl 0:00 /usr/lib/gvfs/gvfsd-trash --spawner :1.1 /org/gtk/gvf
2917 ? Sl 0:00 /usr/lib/arm-linux-gnueabihf/libmenu-cache1/libexec/m
2922 ? S 0:00 /usr/lib/gvfs/gvfs-gphoto2-volume-monitor
2925 ? Sl 0:00 /usr/lib/gvfs/gvfs-afc-volume-monitor
2931 ? Sl 0:00 /usr/lib/arm-linux-gnueabihf/libmenu-cache1/libexec/m
2938 ? Sl 0:00 /usr/lib/gvfs/gvfsd-trash --spawner :1.1 /org/gtk/gvf
2975 ? S 0:51 Xtightvnc :2 -desktop X -auth /home/pi/.Xauthority -g
2979 ? S 0:00 /bin/sh /home/pi/.vnc/xstartup
2982 ? S 0:00 /usr/bin/ck-launch-session /usr/bin/dbus-launch --exi
3004 ? Ss 0:00 /usr/bin/ssh-agent /usr/bin/ck-launch-session /usr/bi
3009 ? Sl 0:00 /usr/bin/lxsession -s LXDE-pi -e LXDE
3012 ? S 0:00 /usr/bin/dbus-launch --exit-with-session x-session-ma
3013 ? Ss 0:00 /usr/bin/dbus-daemon --fork --print-pid 5 --print-add
3021 ? S 0:01 openbox --config-file /home/pi/.config/openbox/lxde-p
3023 ? Sl 0:25 lxpanel --profile LXDE-pi
3025 ? Sl 0:18 pcmanfm --desktop --profile LXDE-pi
3030 ? Sl 0:00 /usr/lib/arm-linux-gnueabihf/lxpolkit
3033 ? S 0:00 /usr/lib/gvfs/gvfsd
3039 ? Sl 0:00 /usr/lib/gvfs/gvfs-gdu-volume-monitor
3043 ? S 0:00 /usr/lib/gvfs/gvfs-gphoto2-volume-monitor
3045 ? Sl 0:00 /usr/lib/gvfs/gvfs-afc-volume-monitor
3050 ? Sl 0:00 /usr/lib/arm-linux-gnueabihf/libmenu-cache1/libexec/m
3053 ? Sl 0:00 /usr/lib/gvfs/gvfsd-trash --spawner :1.2 /org/gtk/gvf
3073 ? Sl 0:00 pcmanfm --desktop --profile LXDE-pi
3124 ? Sl 0:00 pcmanfm --desktop --profile LXDE-pi
3142 ? S 0:01 [kworker/0:1]
3257 ? Sl 0:12 lxterminal
3258 ? S 0:00 gnome-pty-helper
3259 pts/0 Ss+ 0:00 /bin/bash
3591 ? S 0:00 [kworker/0:0]
3594 ? Ss 0:00 sshd: pi [priv]
3598 ? S 0:00 sshd: pi@pts/1
3599 pts/1 Ss 0:01 -bash
There is no RexCore running on your Raspberry Pi. Try running
sudo runrexfrom the command line. Paste here the output.
If you get errors, rename the executive file so that RexCore starts blank.
sudo mv /rex/rexcore/exec.rex /rex/rexcore/exec.bakAfterwards run
sudo runrexagain. Now you should be able to connect and download your project.
Terminate RexCore by Ctrl+C and paste here the output. This will help in identifying the cause of the problem. Thanks.
Still had errors after but it eventually worked. Thanks,
Can one receive e-mail alerts when using Rex on unipi?
Glad I could help.
See https://www.rexcontrols.cz/forum/viewto … pid=16#p16 about alerting.
Hi, I found that the Lighttpd server is slow on the Raspberry PI, I am not sure if this is down to my hardware/ router etc.
I have setup a button using inkscape and the response time is normally 4sec from button press to relay activation. Is this normal?
No, that's not normal unless you defined such a slow sampling period. Can you please test the \UniPi_examples\02_ButtonBlink example from our GitHub repository to decide whether the problem is e.g. in your router?
Do you get any errors in the HMI? You would find it in the upper right corner of the HMI.
Today I got the same problem. At a certain moment I was not able to download my project changes anymore. Every Time I got the 'socket error' message.
Connecting through SSH with putty was still possible thus I rebooted my RaspI (terminal) but the problem remained the same.
pi@REXControl ~ $ ps ax
PID TTY STAT TIME COMMAND
1 ? Ss 0:00 init [2]
2 ? S 0:00 [kthreadd]
3 ? S 0:00 [ksoftirqd/0]
5 ? S< 0:00 [kworker/0:0H]
6 ? S 0:00 [kworker/u8:0]
7 ? R 0:00 [rcu_preempt]
8 ? S 0:00 [rcu_sched]
9 ? S 0:00 [rcu_bh]
10 ? S 0:00 [migration/0]
11 ? S 0:00 [migration/1]
12 ? S 0:00 [ksoftirqd/1]
14 ? S< 0:00 [kworker/1:0H]
15 ? S 0:00 [migration/2]
16 ? S 0:00 [ksoftirqd/2]
18 ? S< 0:00 [kworker/2:0H]
19 ? S 0:00 [migration/3]
20 ? S 0:00 [ksoftirqd/3]
21 ? S 0:00 [kworker/3:0]
22 ? S< 0:00 [kworker/3:0H]
23 ? S< 0:00 [khelper]
24 ? S 0:00 [kdevtmpfs]
25 ? S< 0:00 [netns]
26 ? S< 0:00 [perf]
27 ? S 0:00 [khungtaskd]
28 ? S< 0:00 [writeback]
29 ? S< 0:00 [crypto]
30 ? S< 0:00 [bioset]
31 ? S< 0:00 [kblockd]
32 ? S 0:00 [kworker/0:1]
33 ? S< 0:00 [rpciod]
34 ? S 0:00 [kswapd0]
35 ? S 0:00 [fsnotify_mark]
36 ? S< 0:00 [nfsiod]
42 ? S< 0:00 [kthrotld]
43 ? S< 0:00 [VCHIQ-0]
44 ? S< 0:00 [VCHIQr-0]
45 ? S< 0:00 [VCHIQs-0]
46 ? S< 0:00 [iscsi_eh]
47 ? S< 0:00 [dwc_otg]
48 ? S< 0:00 [DWC Notificatio]
50 ? S 0:00 [VCHIQka-0]
51 ? S< 0:00 [SMIO]
52 ? S< 0:00 [deferwq]
53 ? S 0:00 [kworker/u8:2]
54 ? S 0:00 [kworker/1:1]
55 ? S 0:00 [mmcqd/0]
56 ? S 0:00 [jbd2/mmcblk0p2-]
57 ? S< 0:00 [ext4-rsv-conver]
60 ? S 0:00 [kworker/1:2]
61 ? S 0:00 [kworker/2:1]
74 ? S 0:00 [kworker/3:1]
175 ? Ss 0:00 udevd --daemon
302 ? S 0:00 udevd --daemon
309 ? S 0:00 udevd --daemon
386 ? S< 0:00 [kworker/0:1H]
1023 ? S< 0:00 [kworker/1:1H]
1204 ? S< 0:00 [kworker/2:1H]
1526 ? S 0:00 /usr/sbin/ifplugd -i lo -q -f -u0 -d10 -w -I
1528 ? S 0:00 /usr/sbin/ifplugd -i eth0 -q -f -u0 -d10 -w -I
1770 ? S 0:00 [kworker/0:2]
1968 ? Ss 0:00 /usr/sbin/thd --daemon --triggers /etc/triggerhappy/triggers.d/ --socket /var/run/thd.sock
2008 ? S< 0:00 [cfg80211]
2009 ? Sl 0:00 /usr/sbin/rsyslogd -c5
2092 ? S 0:00 /usr/sbin/cnid_metad -l log_note
2128 ? Sl 0:08 /usr/sbin/afpd -U uams_dhx2.so,uams_clrtxt.so -g nobody -c 50 -n REXControl
2130 ? Ss 0:00 /usr/sbin/cron
2172 ? Ss 0:00 /usr/bin/dbus-daemon --system
2185 ? S 0:00 /usr/bin/RexWSTcp
2202 ? Ss 0:00 /usr/sbin/nmbd -D
2210 ? Ss 0:00 /usr/sbin/ntpd -p /var/run/ntpd.pid -g -u 104:107
2242 ? Ss 0:00 /usr/bin/owserver -c /etc/owfs.conf --pid-file /var/run/owfs/owserver.pid
2255 ? S 0:00 avahi-daemon: running [REXControl.local]
2258 ? S 0:00 avahi-daemon: chroot helper
2280 ? Ss 0:00 /usr/sbin/sshd
2287 ? Ss 0:00 /usr/sbin/smbd -D
2335 ? S 0:00 /usr/sbin/smbd -D
2357 ? S 0:00 /usr/sbin/lighttpd -f /etc/lighttpd/lighttpd.conf
2444 ? Ss 0:00 /sbin/dhcpcd
2456 ? S 0:00 sudo python /home/pi/picofssd.py
2461 ? Ss 0:00 startpar -f -- rc.local
2463 ? S 0:00 python /home/pi/picofssd.py
2468 tty1 Ss+ 0:00 /sbin/getty --noclear 38400 tty1
2469 tty2 Ss+ 0:00 /sbin/getty 38400 tty2
2470 tty3 Ss+ 0:00 /sbin/getty 38400 tty3
2471 tty4 Ss+ 0:00 /sbin/getty 38400 tty4
2472 tty5 Ss+ 0:00 /sbin/getty 38400 tty5
2473 tty6 Ss+ 0:00 /sbin/getty 38400 tty6
2476 ? S 0:00 [kworker/2:2]
2512 ? Ss 0:00 sshd: pi [priv]
2516 ? R 0:00 sshd: pi@pts/0
2521 pts/0 Ss 0:00 -bash
2537 ? S 0:00 [kworker/0:0]
2539 pts/0 R+ 0:00 ps ax...no REXcore....so tried to restart as described in previous post
pi@REXControl ~ $ sudo runrex
Found PID, but no running RexCore found, removing /var/run/rexcore.pid
[ CORE ][ INFO ] ****** Start of REX diagnostics: Date: Mon Apr 4 15:44:56 2016 ******
[ CORE ][WARNING] Authentication module: File open error
[ CORE ][WARNING] TARGET DEVICE CAN BE ACCESSED BY ANYONE!
[ CORE ][WARNING] Swapping configurations
RexCore: terminated by signal 11
Segmentation fault....
pi@REXControl ~ $ sudo mv /rex/rexcore/exec.rex /rex/rexcore/exec.bak
[ CORE ][ INFO ] ****** Start of REX diagnostics: Date: Mon Apr 4 15:46:20 2016 ******
[ CORE ][ ERROR ] Failed to load active configuration: File open error
[ OS ][WARNING] RexCore: stopped by signal 2
^C[ARCHIVE][ INFO ] Log archive deleting...
pi@REXControl ~ $ ^C
[ CORE ][ INFO ] ****** Start of REX diagnostics: Date: Mon Apr 4 15:54:11 2016 ******
.......any idea what could be wrong here?
Segmentation fault means that RexCore has crashed. This is a serious problem. Can you please send all the project files to support@rexcontrols.com so we can have a look at it a hunt this bug?
On your Raspberry Pi, run
sudo rm /rex/rexcore/exec.rexand you will be able to run RexCore again.
Yesterday eve I reinstalled everything (fresh REXcontrols and updated to the Jessie distro on my RasPi)
The problem with the socket occurred to me once more in the past. It seems that it is related to the DbDrv driver.
Today I'll try to provoke the same error and then I'll send you the project files....
(but first I'll backup my SD card... :-) )
...today I had the same problem and it appeared after changing the .rio file from the DbDrv driver.
Before it only contained only code to read data from a database and this was working fine. Now I added some code to store data from REX to my dB but directly after downloading the socket error came up.
After changing the permissions of the database to grant remotely access to the database I was able to connect with REXview again.....so I think it is solved.
Hi scoobsalamander,
thanks for the report! We do not consider this solved by far. Please send us the configuration files which result in the segmentation fault. A description of the changes in the database configuration which made it work will be highly appreciated. Thanks in advance.
mysql> GRANT ALL PRIVILEGES ON *.* TO 'USERNAME'@'1.2.3.4' IDENTIFIED BY 'PASSWORD' WITH GRANT OPTION;This query I used to give the MySql user, which I'm using for the REXcontrols, the necessary privileges. If you are running the MySQL server on the same PC then you will not have this problem I guess....
If I have some time I'll setup a new database with a new user to try to provoke another socket error. (I'm new to all this so it might take some time....and I don't want to destroy my current project because it is finally working).
I also don't know if I had a segmentation fault last time, I forgot to check.....
To be continued..... :-)
