I'm using read function to receive data from socket.
Read(socket, buffer, 1000);Here is an exapmle of recived data.
+00.014 +00.321 +09.878 +00.000 -00.007 -00.001 +01.076 +08.606 +20.051 000016350 146803493Is it posible to separate each nuber by using GetExtDouble();??? How??
I would suggest to use
long Read(long handle, string data[], long count)to read the data from socket directly to String variable.
Data can be parsed using String oriented functions such as:
long strfind(str,substr); // find space occurrence
string strsub(str,idx,len); // parse numberHope it will guide you to the right direction.
Thank you.
Any suggestions how to convert resulting string to double?
Glad I could help.
Look for
double str2double(str)in order to convert string to double.
