Hi
I have mark a block as following images. What is its function ?
Gain is just multiplication of the input by specified constant - see GAIN documentation
Hi
I know GAIN. My Question is Why i use it in this example ? those GAIN have input but no output ?
The GAINs have no special meaning in this example, I think. It just shows that you can do with the signal whatever you want.
Previous version of RexDraw not show values on From and Goto block in online mode, so without any block connected to MTS__xxx blocks you are not able see the value. This is (in my opinion) main reason for using the GAIN blocks in the example, but you can use almost any block for this purpose.
