#1 2016-03-01 09:55:38
jinyistudio
Website
REX Control System for Linux
Hi
Does the Linux(debian) Based industrial PC has any requirements on hardware ?
#2 2016-03-01 11:07:32
Re: REX Control System for Linux
There are no special requirements. RexCore for Debian should run on any x86 platform with Ethernet connection (either wired or wifi). If you have some specific hardware in mind, just post here the specs.
#3 2016-03-02 02:35:58
jinyistudio
Website
#4 2016-03-02 17:53:41
Linux (and thus also Debian) has problems with the graphics driver of this hardware. If you plan to use it headless, this is no limitation.
REX will work with the following limitations:
  • No realtime behavior, although 5ms cycle time should be fine.
  • No direct access to DIO.
  • No direct access to CAN bus.
  • No direct access to OLED display.
Sorry for not having better news at the moment.
#5 2016-03-03 02:23:15
jinyistudio
Website
Hi
Does the Sampling rate could be 1 ms if my system is Linux(debian)+Xenomai ?
debian+Xenomai = 1ms
debian = 5 ms
#6 2016-03-03 07:37:45
jinyistudio
Website
#7 2016-03-03 13:17:09
Yes, with real-time Linux you can achieve 1ms sampling rate. The problem is that running real-time Linux on a particular hardware is not an easy task and requires significant amount of man-hours.
At the moment we use Advantech ARK 1503 or Lanner LEC 2055 for which we have precompiled Linux images which you might be able use.
