#1 2018-11-09 16:32:05
tazntex
Pull-up / Pull-down Switch
          After searching the online manual to find a function block that would allow me to create a "Pull-up" or "Pull-down" switch for use with the raspberry pi gpio pins,  any suggestions?
I am using a CNB" function tied to a "GOTO" referencing the GPIO I am pulling low and it is responding but do want to make certain this is the correct way to do so.
Thank you.
#2 2018-11-12 08:35:09
Re: Pull-up / Pull-down Switch
Hi tazntex,
your approach is absolutely perfect. Did you go through the Getting started guide for REXYGEN on Raspberry Pi? I believe namely the chapter 5 answers your questions.
