#1 2016-10-31 20:49:37
uxhamby
REXduino_slave.ino compile error(s)
I am interested in RexDuino. I have no prior Arduino experience.
I bought a brand new Arduino clone for this purpose.
It is apparently functional.
I have installed the Arduino IDE freshly downloaded from the Arduino site yesterday: V 1.6.12
I have successfully compiled and loaded a test sketch that blinks on board LED.
I have edited the program to alter the LED flash timing. All appears to work as advertised so far.
The IDE's 'Get Board info' function returns:
BN: Arduino/Genuino Uno
VID: 2341
PID: 0243
SN: 8553130323135121C131
I have today downloaded all the files contained in the
https://github.com/jaroslavs/REXduino/t … uino_slave
folder
I have opened the file 'REXduino_slave.ino' in the Arduino IDE and attempted to verify / compile it.
At this point I get a raft of errors that I do not understand or find mentioned in the RexDuino User Guide pdf Trouble shooting section.
Errors are as follows:
Your advice would be appreciated.
Arduino: 1.6.12 (Windows XP), Board: "Arduino/Genuino Uno"
C:\Program Files\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files\Arduino\hardware -tools C:\Program Files\Arduino\tools-builder -tools C:\Program Files\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files\Arduino\libraries -libraries C:\Documents and Settings\Administrator\My Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0X2341_0X0243 -ide-version=10612 -build-path C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672 -warnings=none -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Program Files\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files\Arduino\hardware\tools\avr -verbose C:\Documents and Settings\Administrator\My Documents\Arduino\REXduino-master\REXduino_slave\REXduino_slave.ino
C:\Program Files\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files\Arduino\hardware -tools C:\Program Files\Arduino\tools-builder -tools C:\Program Files\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files\Arduino\libraries -libraries C:\Documents and Settings\Administrator\My Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0X2341_0X0243 -ide-version=10612 -build-path C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672 -warnings=none -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Program Files\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files\Arduino\hardware\tools\avr -verbose C:\Documents and Settings\Administrator\My Documents\Arduino\REXduino-master\REXduino_slave\REXduino_slave.ino
Using board 'uno' from platform in folder: C:\Program Files\Arduino\hardware\arduino\avr
Using core 'arduino' from platform in folder: C:\Program Files\Arduino\hardware\arduino\avr
Detecting libraries used...
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10612 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\standard" "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\sketch\REXduino_slave.ino.cpp" -o "nul"
Generating function prototypes...
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10612 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\standard" "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\sketch\REXduino_slave.ino.cpp" -o "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files\Arduino\tools-builder\ctags\5.8-arduino10/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\preproc\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10612 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\standard" "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\sketch\REXduino_slave.ino.cpp" -o "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\sketch\REXduino_slave.ino.cpp.o"
Compiling libraries...
Compiling core...
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc" -c -g -x assembler-with-cpp -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10612 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\standard" "C:\Program Files\Arduino\hardware\arduino\avr\cores\arduino\wiring_pulse.S" -o "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\core\wiring_pulse.S.o"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10612 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\standard" "C:\Program Files\Arduino\hardware\arduino\avr\cores\arduino\WInterrupts.c" -o "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\core\WInterrupts.c.o"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10612 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\standard" "C:\Program Files\Arduino\hardware\arduino\avr\cores\arduino\hooks.c" -o "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\core\hooks.c.o"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10612 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\standard" "C:\Program Files\Arduino\hardware\arduino\avr\cores\arduino\wiring.c" -o "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\core\wiring.c.o"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10612 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\standard" "C:\Program Files\Arduino\hardware\arduino\avr\cores\arduino\wiring_analog.c" -o "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\core\wiring_analog.c.o"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10612 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\standard" "C:\Program Files\Arduino\hardware\arduino\avr\cores\arduino\wiring_digital.c" -o "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\core\wiring_digital.c.o"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10612 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\standard" "C:\Program Files\Arduino\hardware\arduino\avr\cores\arduino\wiring_pulse.c" -o "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\core\wiring_pulse.c.o"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10612 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\standard" "C:\Program Files\Arduino\hardware\arduino\avr\cores\arduino\wiring_shift.c" -o "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\core\wiring_shift.c.o"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10612 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\standard" "C:\Program Files\Arduino\hardware\arduino\avr\cores\arduino\CDC.cpp" -o "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\core\CDC.cpp.o"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10612 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\standard" "C:\Program Files\Arduino\hardware\arduino\avr\cores\arduino\HardwareSerial.cpp" -o "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\core\HardwareSerial.cpp.o"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10612 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\standard" "C:\Program Files\Arduino\hardware\arduino\avr\cores\arduino\HardwareSerial0.cpp" -o "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\core\HardwareSerial0.cpp.o"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10612 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\standard" "C:\Program Files\Arduino\hardware\arduino\avr\cores\arduino\HardwareSerial1.cpp" -o "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\core\HardwareSerial1.cpp.o"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10612 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\standard" "C:\Program Files\Arduino\hardware\arduino\avr\cores\arduino\HardwareSerial2.cpp" -o "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\core\HardwareSerial2.cpp.o"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10612 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\standard" "C:\Program Files\Arduino\hardware\arduino\avr\cores\arduino\HardwareSerial3.cpp" -o "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\core\HardwareSerial3.cpp.o"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10612 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\standard" "C:\Program Files\Arduino\hardware\arduino\avr\cores\arduino\IPAddress.cpp" -o "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\core\IPAddress.cpp.o"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10612 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\standard" "C:\Program Files\Arduino\hardware\arduino\avr\cores\arduino\PluggableUSB.cpp" -o "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\core\PluggableUSB.cpp.o"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10612 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\standard" "C:\Program Files\Arduino\hardware\arduino\avr\cores\arduino\Print.cpp" -o "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\core\Print.cpp.o"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10612 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\standard" "C:\Program Files\Arduino\hardware\arduino\avr\cores\arduino\Stream.cpp" -o "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\core\Stream.cpp.o"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10612 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\standard" "C:\Program Files\Arduino\hardware\arduino\avr\cores\arduino\Tone.cpp" -o "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\core\Tone.cpp.o"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10612 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\standard" "C:\Program Files\Arduino\hardware\arduino\avr\cores\arduino\USBCore.cpp" -o "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\core\USBCore.cpp.o"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10612 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\standard" "C:\Program Files\Arduino\hardware\arduino\avr\cores\arduino\WMath.cpp" -o "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\core\WMath.cpp.o"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10612 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\standard" "C:\Program Files\Arduino\hardware\arduino\avr\cores\arduino\WString.cpp" -o "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\core\WString.cpp.o"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10612 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\standard" "C:\Program Files\Arduino\hardware\arduino\avr\cores\arduino\abi.cpp" -o "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\core\abi.cpp.o"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10612 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\standard" "C:\Program Files\Arduino\hardware\arduino\avr\cores\arduino\main.cpp" -o "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\core\main.cpp.o"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10612 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\standard" "C:\Program Files\Arduino\hardware\arduino\avr\cores\arduino\new.cpp" -o "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\core\new.cpp.o"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\core\core.a" "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\core\wiring_pulse.S.o"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\core\core.a" "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\core\WInterrupts.c.o"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\core\core.a" "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\core\hooks.c.o"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\core\core.a" "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\core\wiring.c.o"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\core\core.a" "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\core\wiring_analog.c.o"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\core\core.a" "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\core\wiring_digital.c.o"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\core\core.a" "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\core\wiring_pulse.c.o"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\core\core.a" "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\core\wiring_shift.c.o"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\core\core.a" "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\core\CDC.cpp.o"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\core\core.a" "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\core\HardwareSerial.cpp.o"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\core\core.a" "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\core\HardwareSerial0.cpp.o"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\core\core.a" "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\core\HardwareSerial1.cpp.o"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\core\core.a" "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\core\HardwareSerial2.cpp.o"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\core\core.a" "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\core\HardwareSerial3.cpp.o"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\core\core.a" "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\core\IPAddress.cpp.o"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\core\core.a" "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\core\PluggableUSB.cpp.o"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\core\core.a" "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\core\Print.cpp.o"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\core\core.a" "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\core\Stream.cpp.o"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\core\core.a" "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\core\Tone.cpp.o"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\core\core.a" "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\core\USBCore.cpp.o"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\core\core.a" "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\core\WMath.cpp.o"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\core\core.a" "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\core\WString.cpp.o"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\core\core.a" "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\core\abi.cpp.o"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\core\core.a" "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\core\main.cpp.o"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\core\core.a" "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\core\new.cpp.o"
Linking everything together...
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc" -w -Os -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p  -o "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672/REXduino_slave.ino.elf" "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672\sketch\REXduino_slave.ino.cpp.o" "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672/core\core.a" "-LC:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_964672" -lm
collect2.exe: error: ld returned 5 exit status
exit status 1
Error compiling for board Arduino/Genuino Uno.
#2 2016-11-02 01:00:02
uxhamby
Re: REXduino_slave.ino compile error(s)
On the advice of a YouTube video (https://youtu.be/KJ1KmtkkLxw) I found on a Google search, I uninstalled the Arduino software version 1.6.12 and re installed an older version 1.0.5.
This seems to have sorted out my compile problems and I can now load the REXduino slave sketch onto my Arduino.
Hope this helps someone.
Cheers,
Brian H.
#3 2016-11-02 07:25:29
Hi Brian,
any chance to try compiling the sketch on a different machine? On my PC with Win7 the sketch compiles fine even in 1.6.12.
Thanks for posting your findings and thanks for your interest in REXduino!
