Getting started with REXYGEN on UniPi Patron
3 Installing the runtime modules of the REXYGEN system on UniPi Patron
3.1 Install using operating system image with REXYGEN
3.2 Manual installation on running UniPi Patron
3.3 Starting the runtime
3.4 Installed files and folders
4 Licensing REXYGEN using REXYGEN DWM on UniPi Patron
4.1 Obtaining a DEMO licence
4.2 Obtaining a permanent licence
4.2.1 Activation of the permanent licence
5 Default REXYGEN project on UniPi Patron
5.1 Control UniPi Patron from HMI
5.2 Control UniPi Patron through OPC UA
5.3 Loading project from UniPi Patron to REXYGEN Studio
6 Configuration, compilation and execution
6.1 Creating a new project
6.2 Compiling and running a project
6.3 Adding a user interface (HMI)
6.4 Ready for interaction with the outer world
7 I/O configuration for the UniPi Patron
7.1 Physical connections
7.2 Adding inputs and outputs to the project
7.3 Working with I/O signals
7.3.1 Modifications in the project main file
7.3.2 Modifications in the task
7.4 Updating the HMI
7.5 Additional information
7.5.1 Detailed description of the driver
7.5.2 Examples
8 Summary
The runtime core of the REXYGEN system turns your UniPi Patron into a programmable device which will run your algorithms.
- Wide family of supported devices and input-output units (including UniPi Patron)
REXYGEN Studio is a developer’s tool which runs on a standard PC with Windows. You create the algorithms using the function block library (The IEC 61131-3 standard defines Function Block Diagram (FBD) as one of the PLC programming techniques.) of the REXYGEN system [1]. The library contains simple comparators and timers as well as advanced blocks for signal processing and feedback control (PID controllers etc.). You compile your project on your PC and run it on your UniPi Patron.
The REXYGEN HMI Designer is another developer’s tool intended for designing graphical user interface (or HMI, Human Machine Interface, if you prefer) for your algorithms. The user interface is included in the project and it is copied to your UniPi Patron along with the algorithm.
The RexCore (REXYGEN runtime core) service runs on the target device (UniPi Patron). Once installed, it runs in the background and therefore it is almost invisible for the user. It handles timing and execution of your algorithms and provides various services. The individual tasks are prioritized and executed using preemptive multitasking. The RexCore service is automatically started at system startup.
RexCore further contains an integrated webserver providing user interface (HMI) and REST API. Chapter 3 deals with installing all the necessary modules on UniPi Patron.
Patron
Before installing the runtime modules of the REXYGEN system, it is possible to backup the
actual state of your UniPi Patron. The process of Cloning, Backup & Restoration of OS
images can be found here:
https://kb.unipi.technology/en:hw:007-patron:image\#creating_a_os_back-up_on_a_usb_flashdisk.
IMPORTANT: This procedure will delete all old data and settings. Make sure you have all the necessary files stored elsewhere!
- It is highly recommended to use the official UniPi Patron OS image with REXYGEN
which you can download from
http://download.rexcontrols.com/images/. - After you download the file, flash the Operating System according to this manual:
https://kb.unipi.technology/en:hw:007-patron:image\#flash_backup_the_os. - The SSH is enabled by default. The username is: rexygen and the password is: rexygen. Please change the password using passwd as soon as possible. The root login via SSH is disabled by default.
It is also possible to install the RexCore (REXYGEN runtime core) on running UniPi Patron manually. Following instructions guide you through installation of REXYGEN runtime on plain UniPi Patron OpenSource OS. See documentation for other platforms for specific installation steps.
- Install some necessary packages:
sudo apt install wget gnupg2 - Add REXYGEN public key:
sudo wget https://download.rexcontrols.com/files/key/rex-debian-key.pub.gpg -O /etc/apt/trusted.gpg.d/rexygen.gpg
- Add the repository to /etc/apt/sources.list or create a new *.list under
/etc/apt/sources.list.d/ with the following content:
deb https://download.rexcontrols.com/rexygen/debian/ bookworm rexygen dwm
Replace bookworm with bullseye or buster if you are still running the older Debian distribution.
sudo apt install rexygen-dwm
Right after the installation, the RexCore runtime module is started automatically in the background as a daemon and it is possible to establish connection between the host PC and the UniPi Patron using the REXYGEN Studio program. RexCore also automatically runs upon system (re)start.
The first thing you will need is to get the license. The fastest way is to use the REXYGEN DWM tool. Open your web-browser and input IP address of UniPi Patron. You should see the Device is not licensed! message on the bottom of the screen. Please, click on the Licensing.
- The RexCore runtime module always needs a licence to run on your UniPi Patron. There are DEMO licences available at no cost and there are permanent licences which you can purchase. Each UniPi Patron needs an individual licence.
Click on Get demo licence and you will be redirected to the registration form. Identify yourself and you’ll receive a DEMO licence key via e-mail. The licence key is called a SiteKey.
Once you have your DEMO licence key (SiteKey), apply it in REXYGEN DWMby selecting Apply Licence Keys and clicking on Apply keys.
Evaluation version of RexCore (REXYGEN runtime core) is functional for 2 hours. It is possible to run your algorithm on the UniPi Patron but you cannot store it permanently. The algorithm resides only in the RAM memory therefore it will not run after a restart or power-up. You can use almost all function blocks, see [1]. The RexCore runtime core on the target device is terminated after 2 hours of operation in demo mode without any warning. After a restart, you have another 2 hours for your experiments.
Each device running the RexCore runtime module is identified by the so-called SiteID tag. The purchased licence is associated with the hardware device, i.e. with the SiteID tag.
- Open your favorite web-browser on the desktop PC and fill in the IP address of
UniPi Patron. Once the DWM appears, select Licensing
Apply Voucher and enter your licence voucher code.
- If other licenses are already present, a new window will appear where you can
specify what should happen to the old licenses. Use the Overwrite option if the
UniPi Patron is running in DEMO mode. This is the last and irreversible
in your device, which is shown in the Active License panel. The licence key allows
permanent operation of the runtime core. It is highly recommended to check the licence
again after a reboot of the device.
In order to help you speed up a start with REXYGEN and UniPi Patron we have create an example project for most UniPi Patron which is already preinstalled on the image with REXYGEN (installation is described in Section 3.1). The project serves as a basic validation of the installation process and as a starting point for more complex applications. One can control digital output(s) DO, analog output(s) AO, observe the state of digital inputs(s) DI and analog input(s) AI. These general inputs and outputs are present on all UniPi Patron models. The steps to create and develop a new project from scratch is described in Chapter 6 in detail.
IMPORTANT: If you have valid permanent licence stored on your UniPi Patron, this
project will start automatically once RexCore (REXYGEN runtime core) starts. Otherwise, if
you have only a Demo license, you must compile and download the project from
the REXYGEN Studio on the UniPi Patron first. The project can be opened in the
REXYGEN Studio using either the procedure described in Section 5.3, or the project
can also be found in the Examples library as 0127-02_UniPi_Patron_Generic (All
examples which are part of the installation are marked by an ExampleID. The most
up-to-date examples are available with the latest installation of development tools or at
https://www.rexygen.com/example-projects/ ).
The process of compiling and running the project is described in Section 6.2.
The project contains graphical user interface (so-called Human-Machine-Interface) for easy control and observing of general outputs and inputs. The HMI can be found at URL address http://192.168.1.100:8008/hmi/index.html (replace 192.168.1.100 with the IP address of your UniPi Patron).
You can use the OPC UA interface to control your UniPi Patron too. Install any OPC UA
Client and connect to the OPC UA Server, which is running right now on your UniPi Patron.
There is the UAExport software used in this tutorial:
https://www.unified-automation.com/downloads/opc-ua-clients.html.
Click on Server in the Menu
Add
Advanced mode and fill the Configuration Name and the Endpoint URL (replace 192.168.1.100
After confirmation (OK), right-click on the new server name in the Project panel and choose Connect.
Congratulations, you are now connected to your UniPi Patron! You can now set the DO1 to value true for example. Navigate to Address Space panel and select DO1. In Attributes panel search Value Value, double-click on it, check the radio box and hit Enter. The first Digital outputs LED diod on UniPi Patron should glow. Detailed tutorial on using OPC UA with REXYGEN is there [3].
After installation of REXYGEN development tools (described in Chapter 2), you can open the REXYGEN Studio on your PC and download algorithm of this default project from your UniPi Patron.
Select Load Project from Target Device from starting dialog or from File Open Project from Target Device and connect to your UniPi Patron (replace 192.168.1.100 with the IP address of your UniPi Patron).
Choose the directory where will be the project stored on your PC and hit OK.
If everything went well, the project algorithm will appear.
The process of creating a control algorithm will be demonstrated on a very simple example with four Boolean variables representing manual switches. In Chapter 7.3, two of them will be replaced by physical inputs of the UniPi Patron. A software timer will be used for measuring the time when the variables are true (i.e. the switches are in the ON position). A Boolean signal will indicate that the interval of predefined length has elapsed.
Enter the IP address of your UniPi Patron in the Target field.
If there is no licence on your UniPi Patron, you need to get one first. You can get a DEMO licence for free. See Appendix B for details and come back afterwards.
All changes made while in the Watch mode are not permanently stored in the target device (unless you decide so, see [4]). Upon restarting the RexCore runtime module the algorithm will start with the parameters defined in the project source files, which were valid when compiling and downloading the algorithm to the target device. To apply the changes permanently, you have to transfer the changes to the source files and Compile and download the project one more time which defines new startup values.
moment. See [5] for details, it is a very interesting tool for developers and
- See [5] for detailed information about WebBuDi elements and possible customization (colors, backgrounds etc.).
- The default URL address is http://192.168.1.100:8008/hmi/index.html (replace 192.168.1.100 with the IP address of your UniPi Patron).
We will use the input and output signals of the UniPi Patron for interaction with the real world.
As mentioned in Chapter 6, two physical switches will be connected as inputs and a software timer will control one output signal. In other words, this chapter is devoted to advancing from the generic example 0101-01 to example 0127-01 for the UniPi Patron.
Connect the switches as shown below.
Now we tell the compiler to use the UniPi Patron I/O driver. To do this, edit the IODRV block parameters. Communication will be mediated using Modbus TCP. Link the IODRV block with the MBDrv (Modbus) module by setting
- (beware, it’s CASE SENSITIVE!)
Continue editing the IODRV block parameters. For UniPi Patron set the following:
As the final step, rename the IODRV block to PTN, which will serve as a prefix for all I/O signals of this driver.
You have to create the patron_cfg.rio file. Click on Configure button and fill the form as shown bellow. After that, click on OK and the file will be stored in the project folder.
In the task double-click the input flag and set . Note the PTN prefix and two underscore characters. The first physical switch (SW1) is connected to first group of Digital Inputs - input 1.
The other physical switch (SW3) is connected to Digital Input 1.3 (PTN__DI1_3). The last (Digital Output) flag will be set as
After compiling the project and downloading it to the UniPi Patron the control algorithm interacts with the physical world. Again it is possible to switch to Watch mode and observe the signals in real-time or analyze the trends of signals. Flip the physical switches and watch the signals.
A detailed description of the Modbus TCP IO driver which serves as communication platform for UniPi Patron is available in a separate manual [6].
7.5.2 Examples
Start from an Example Project and select one of the UniPi Patron examples. As
Congratulations, you have created the example from scratch! You have learned how to develop, compile and run your algorithms on the UniPi Patron. The interaction with sensors and actuators is provided via input-output driver of the REXYGEN system, which you have learned to configure and use.
Chapter 6 describes the creation of a simple WebBuDi user interface. The REXYGEN development tools also contain the REXYGEN HMI Designer program which is a tool for designing custom graphical visualizations from predefined components (Definition of custom components is also possible but it requires a bit of Javascript coding.). The REXYGEN HMI Designer is based on the well-known open-source vector editor InkscapeTM https://inkscape.org/en/.
You can find the description of each component and property in [5]. Leave the default values
The Browser requires a target device with running algorithm. Make sure the algorithm is running, see Section 6.2. Also the target URL must be set. Press Browse button. The login dialog will be opened. Change Target to 192.168.1.100:8008 (replace 192.168.1.100 with the IP address of your UniPi Patron). Unless you changed the login credentials, use the default username admin with an empty password. After a successful login the connection tab is expanded with a tree-view of the running algorithm (you have already seen this tree-view in algorithm diagnostics).
As mentioned earlier, the *.hmi.svg files in the hmisrc folder are automatically processed while the project is compiled in the REXYGEN Studio application. The project main file must contain the HMI block with GenerateRexHMI parameter enabled. This was already covered in Section 6.3 so you should have everything ready.
Once you compile the project again and download it to your UniPi Patron, the HMI will be
accessible via a web browser. Navigate to
of your UniPi Patron). You will see your HMI with live data.
This tutorial covers only the very basic components. If you want to get more information about additional components, see [5].
Once successfully applied, your algorithm will download to your UniPi Patron.
[3] REX Controls s.r.o.. OpcUaDrv driver of REXYGEN – user guide, 2020. .
[4] REX Controls s.r.o.. REXYGEN Studio – User manual, 2020. .
[5] REX Controls s.r.o.. REXYGEN HMI – User manual, 2020. .
[6] REX Controls s.r.o.. Modbus driver of REXYGEN – User guide, 2020. .
