Getting started with REXYGEN on Debian
3 Installing the runtime modules of the REXYGEN system on Debian GNU/Linux
3.1 Supported architectures
3.2 Installation on REXYGEN runtime
3.2.1 Installation with a script
3.2.2 Manual installation
3.3 Starting the runtime
3.4 Installed files and folders
3.5 Uninstall procedure
4 Configuration, compilation and execution
4.1 Creating a new project
4.2 Compiling and running a project
4.3 Adding a user interface (HMI)
4.4 Ready for interaction with the outer world
5 Summary
The runtime core of the REXYGEN system turns your Debian GNU/Linux into a programmable device which will run your algorithms.
- Wide family of supported devices and input-output units (including Debian)
REXYGEN Studio is a developer’s tool which runs on a standard PC with Windows. You create the algorithms using the function block library (The IEC 61131-3 standard defines Function Block Diagram (FBD) as one of the PLC programming techniques.) of the REXYGEN system [1]. The library contains simple comparators and timers as well as advanced blocks for signal processing and feedback control (PID controllers etc.). You compile your project on your PC and run it on your Debian GNU/Linux.
The REXYGEN HMI Designer is another developer’s tool intended for designing graphical user interface (or HMI, Human Machine Interface, if you prefer) for your algorithms. The user interface is included in the project and it is copied to your Debian GNU/Linux along with the algorithm.
The RexCore (REXYGEN runtime core) service runs on the target device (Debian GNU/Linux). Once installed, it runs in the background and therefore it is almost invisible for the user. It handles timing and execution of your algorithms and provides various services. The individual tasks are prioritized and executed using preemptive multitasking. The RexCore service is automatically started at system startup.
RexCore further contains an integrated webserver providing user interface (HMI) and REST API. Chapter 3 deals with installing all the necessary modules on Debian GNU/Linux.
GNU/Linux
It is necessary to have a correctly configured Internet connection on your machine running the Debian distribution of GNU/Linux (RexCore should also work on any other distribution based on Debian (e.g. Ubuntu).) prior to using this guide. Visit https://www.debian.org/ for more information.
Following CPU architectures are supported by REXYGEN runtime: i386, amd64, armhf, aarch64.
REXYGEN runtime may be installed by adding a repository to the source list manually or with a script that automates all the installation tasks.
Run these commands in a terminal to run automatic interactive installation and follow instructions on the screen.
chmod +x rex-install-debian.sh
sudo ./rex-install-debian.sh
These scripts always install the stable branch of REXYGEN. The scripts also provide --testing and --next parameters to install development branches. The "testing" branch contains a REXYGEN version that is to be released soon, but still under testing. The "next" branch contains the current state of a next REXYGEN version under development. Use these options carefully.
Following instructions guide you through installation of REXYGEN runtime on plain Debian GNU/Linux. See documentation for other platforms for specific installation steps.
- Add REXYGEN public key:
sudo wget https://download.rexcontrols.com/files/key/rex-debian-key.pub.gpg -O /etc/apt/trusted.gpg.d/rexygen.gpg
- Add the repository to /etc/apt/sources.list or create a *.list under /etc/apt/sources.list.d/
with the following content:
deb https://download.rexcontrols.com/rexygen/debian/ bookworm rexygen dwm
Replace bookworm with bullseye or buster if you are still running the older Debian distribution.
sudo apt install rexygen-dwm - Perform specific installation steps for your platform.
Right after the installation, the RexCore runtime module is started automatically in the background as a daemon and it is possible to establish connection between the host PC and the Debian GNU/Linux using the REXYGEN Studio program. RexCore also automatically runs upon system (re)start.
Use the following commands to remove REXYGEN runtime from the operating system:
sudo apt-get remove rexygen-dwm
sudo apt-get autoremove
The process of creating a control algorithm will be demonstrated on a very simple example with four Boolean variables representing manual switches. In Chapter ??, two of them will be replaced by physical inputs of the Debian. A software timer will be used for measuring the time when the variables are true (i.e. the switches are in the ON position). A Boolean signal will indicate that the interval of predefined length has elapsed.
Enter the IP address of your Debian GNU/Linux in the Target field.
If there is no licence on your Debian GNU/Linux, you need to get one first. You can get a DEMO licence for free. See Appendix B for details and come back afterwards.
All changes made while in the Watch mode are not permanently stored in the target device (unless you decide so, see [3]). Upon restarting the RexCore runtime module the algorithm will start with the parameters defined in the project source files, which were valid when compiling and downloading the algorithm to the target device. To apply the changes permanently, you have to transfer the changes to the source files and Compile and download the project one more time which defines new startup values.
moment. See [4] for details, it is a very interesting tool for developers and
- See [4] for detailed information about WebBuDi elements and possible customization (colors, backgrounds etc.).
- The default URL address is http://192.168.1.100:8008/hmi/index.html (replace 192.168.1.100 with the IP address of your Debian).
Congratulations, you have created the example from scratch! You have learned how to develop, compile and run your algorithms on the Debian GNU/Linux. The interaction with sensors and actuators is provided via input-output driver of the REXYGEN system, which you have learned to configure and use.
Chapter 4 describes the creation of a simple WebBuDi user interface. The REXYGEN development tools also contain the REXYGEN HMI Designer program which is a tool for designing custom graphical visualizations from predefined components (Definition of custom components is also possible but it requires a bit of Javascript coding.). The REXYGEN HMI Designer is based on the well-known open-source vector editor InkscapeTM https://inkscape.org/en/.
You can find the description of each component and property in [4]. Leave the default values
The Browser requires a target device with running algorithm. Make sure the algorithm is running, see Section 4.2. Also the target URL must be set. Press Browse button. The login dialog will be opened. Change Target to 192.168.1.100:8008 (replace 192.168.1.100 with the IP address of your Debian). Unless you changed the login credentials, use the default username admin with an empty password. After a successful login the connection tab is expanded with a tree-view of the running algorithm (you have already seen this tree-view in algorithm diagnostics).
As mentioned earlier, the *.hmi.svg files in the hmisrc folder are automatically processed while the project is compiled in the REXYGEN Studio application. The project main file must contain the HMI block with GenerateRexHMI parameter enabled. This was already covered in Section 4.3 so you should have everything ready.
Once you compile the project again and download it to your Debian GNU/Linux, the HMI
will be accessible via a web browser. Navigate to
of your Debian). You will see your HMI with live data.
This tutorial covers only the very basic components. If you want to get more information about additional components, see [4].
- The RexCore runtime module always needs a licence to run on your Debian GNU/Linux. There are DEMO licences available at no cost and there are permanent licences which you can purchase. Each Debian GNU/Linux needs an individual licence.
Once successfully applied, your algorithm will download to your Debian.
Evaluation version of RexCore (REXYGEN runtime core) is functional for 2 hours. It is possible to run your algorithm on the Debian but you cannot store it permanently. The algorithm resides only in the RAM memory therefore it will not run after a restart or power-up. You can use almost all function blocks, see [1]. The RexCore runtime core on the target device is terminated after 2 hours of operation in demo mode without any warning. After a restart, you have another 2 hours for your experiments.
[3] REX Controls s.r.o.. REXYGEN Studio – User manual, 2020. .
